quick steering shaft question
Discussion in 'The Garage' started by suntadz, Apr 21, 2007.
  1. suntadz
    suntadz 1/2 ton status
    May 15, 2005
    187
    bay area, ca
    i was replacing my stering shaft with one of those ujoint types. My problem is on the gear box splined shaft there seems to be a metal rod protruding out of the center 1/2". this hit the ujoint before the shaft is fully made up. Am i supposed to just cut this off? any harm in cutting it off? ill try to get a pic. thanks
  2. suntadz
    May 15, 2005
    187
    bay area, ca
    ok here is a pic:
  3. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    Hi,
    I bought a Borgesun 935 and it is designed so that the nipple on the spline slides into the yoke on the steering shaft and does not interfere. I'm sure the nipple is there for a reason, so I cannot comment on whether to remove it or not. Looks like you bought the Borgesun too! What version number?
    Manny
  4. suntadz
    May 15, 2005
    187
    bay area, ca
    i got the 935 aswell. hmm. ill look down the shaft and see if it got a hole in the joint for it. thanks
    ok it does look like there is a grove in the joint the little tit can go into . real close to hitting it. Thought it was a little close for comfort but maybe i was just tripping. got it on and tight and going for a test drive. l8r thanks for the tip.
