quick tie rod question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wkbrdrob, Jul 6, 2006.
  1. wkbrdrob
    wkbrdrob Registered Member
    Feb 7, 2006
    63
    Salem, OR
    Will the tie rod from an '86 10B fit an '86 8-lug Dana 44?
  2. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    not really, its about 3/4 to an inch too long, you need to adjust it all the way in and hope it will still work. Personally, i just found a 1987 1/2 one that has 2 removable ends on it and cut off some of the ends to make it narrower then ran it and it works fine. BTW, there is no 86 8lug d44. There is a 86 10 bolt. Where are the knuckles from because the earlier knuckles have the tie rod upside down vs right side up. The stablilizer is in a different spot on certain (early) d44 housings.
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    AFAIK the tie rods are the same length but D44 come in from one direction and the 10 bolts come in from the other direction. It is a D60 when the tie rod changes and can't be used.
  4. KevinsK5
    KevinsK5 1/2 ton status Premium Member
    Jan 17, 2005
    257
    13
    Golden, CO
    Didn't know that. Thought D44 tierods were all the same.
    Thats correct.:D Kevin
  5. onetonbb74
    Dec 1, 2005
    2,083
    Campbell, CA
    last year i did the tie rod thing and i had a 1/2 ton 10 bolt 1979, 3/4 ton 10 bolt 1979, 1974 d44 3/4 ton, and a d60 all in my garage. Not any of the tie rods were the same length, and the d44 had a different mount for the stabilizer and it was upside down compared to the 10 bolt.
  6. KevinsK5
    Jan 17, 2005
    257
    13
    Golden, CO
    Wierd. Thats good to know though. If I ever bend a tierod and need a new (junkyard) one, at least now I won't waste my money cause I thought they were all the same.:thumb: Kevin
  7. wkbrdrob
    Feb 7, 2006
    63
    Salem, OR
    good to know. Thanks guys!
