quick tire ques...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by **b**, Aug 22, 2000.
  1. **b**
    **b** 1/2 ton status
    279
    KIllington, VT.
    I know this issue has been addressed numerous times
    in the Forum / but as some of you may know i am too lazy
    to search history....
    87 stock set up
    32's or 33's ?????
  2. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    I have 33's with a 3" bodylift. Works fine for me.
    [​IMG] Semper Maintenance!
  3. 86blazerk5
    86blazerk5 1/2 ton status
    Aug 9, 2000
    387
    Hagarstown, Maryland
    If you dont want to lift it, body or spring, and you dont want to trim your fenders, and you dont want it to rub, 32s, if you are thinking of a two inch spring or body lift, or more, 33s, if you dont mind trimming your fenders, 33s, or idf you dont mind az little rubbing, 33s. Basically, #3s will rub when you turn the wheel all the way, they will hit the back of the fender well, that is 33X12.5s, I am assuming 12.5s, becuase those atre most common. so, you make the decision.
    Ike
    Jeep, what every boy dreams of... K5 what every man owns!!!
  4. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    I had my 33's on for a month before my 4" lift was put in and it only rubbed when I hit a steep driveway or hill while turning. They should fit fine with a little trimming. It looks d@mn cool too. My next project is 37's with my 4" lift and a sawzall.
    Joe
    Rochester Institute of Technology Team Mini-Baja
    88 Jimmy
  5. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    <font color=blue>I am currently running 33/12.50/15 tires on a stock 85 with no lift. I get minimal tire rub on the inside wheel well... although it comes very close to hitting the front fender edges when turning. It really depends on the tires. Not all measure exactly to what they say they are. I'd say just try them out then go from there. </font color=blue>
    BLAZE IT UP!!!
