quick torque converter question
Discussion in 'The Garage' started by sams78chevy, Sep 30, 2005.
  1. sams78chevy
    sams78chevy Registered Member
    Apr 24, 2005
    65
    oregon
    I was just wondering how you make sure that the torque converter is seated properly? I am pretty sure it is on there good but I need a second opinion.Thanks for the help.
  2. sweetk30
    Nov 1, 2004
    25,536
    532
    horseheads , ny 14845
    you should feel 3 movments as you slide it on.
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    And you can definitely feel it seat in the pump drive. If you have any doubts, it's probably not fully seated. I'm always a bit surprised at how far in it tucks.
    Then, just to be on the safe side, while you're lining up the bell housing alignment dowels, keep an eye on the converter to flex plate clearance. If they ever touch, you don't have it seated. Once fully against the block, you should have to pull the converter back out at least 1/8" or so to get it on the flex plate. Even if you KNOW it was seated when you started, you should keep an eye on that since it could potentially unseat while jostling the trans around to get it in place...
