QUICK!! TQ spec for TBI bolts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jarheadk5, Mar 25, 2001.
  1. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Just installed a new TBI-to-intake manifold gasket, and I need the torque for the TBI mount bolts. I can't find it in Haynes. Thanks!
    [​IMG] Semper Maintenance!
  2. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Torque specs?, um, I go with 3 "bapps" with my Snap on 3/8 gun, about 2 "bapps" with a Matco or I/R, 4 with a Blue point, and empty the tank with a craftsman impact.
    Twiztid
  3. jarheadk5
    Mar 6, 2000
    4,389
    PA
    Well, my calibrated arm is in the shop, and my air comp. and airtools still only exist in my mind, so what I really need is the number I should set my torque wrech for!
  4. slider79blazer
    slider79blazer 1/2 ton status
    Mar 23, 2001
    164
    littleton,co.
    my buddy just put one on a couple weeks again and said it was 5-7 ft. lbs. for the spacer plate and to the manifold.
  5. jarheadk5
    Mar 6, 2000
    4,389
    PA
    Thanks.
  6. slider79blazer
    Mar 23, 2001
    164
    littleton,co.
    no problem!!! if you need more let me know. He is a wiz with
    that stuff.
  7. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    I honestly don't know what th specs are. I would check the book for some other bolt that is close the the size and length, and use that (T.B.I. bolts are a 10mm about 3 in long 13mm head, if my memmorys serves) It will not make or brake you, just tighten them down. I'd say to about 10 to 15 ft/lbs if I were to guess.
    Twiztid
    <P ID="edit"><FONT SIZE=-1>Edited by Twiztid on 03/25/01 04:33 PM (server time).</FONT></P>
