quick tranny question
Discussion in 'The Garage' started by k5bl, Jul 6, 2005.
  1. k5bl
    k5bl Registered Member
    Feb 1, 2005
    48
    Bushkill,PA
    want to drop the pan,change the filter,and put new atf. how many quarts do I need? its a 700r trans.
  2. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    just pan? 4ish
  3. ntx78k5
    ntx78k5 1/2 ton status
    Oct 22, 2004
    166
    Home of the Rangers
    I did that over the weekend on a TH350, first timer doing that and there was a lot of gray thick almost grease consistancy crap in the pan. what the hell was that crap. No metal..
    on a TH350 it was 3.5 quarts
  4. k5bl
    Feb 1, 2005
    48
    Bushkill,PA
    also whats a good name atf to use?
  5. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    i LOVE AMSOIL. best stuff ever. other then that about all the same. NAPA is good n cheap
  6. seschev3
    seschev3 1/2 ton status
    Jan 19, 2005
    308
    clayton, ca
    A 700r4 with torque converter and cooler holds around 11 to 13 quarts of atf. I use valvaline for all my oil, trans, gear and grease. I also use the Felpro rubber gaskets for the pan. Can't stand the cork and paper gaskets, always seem to leak after a while.
  7. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    a filter change for a 700r4 is 5 quarts, buy 6 though. ive done 2 that needed 5.5 quarts
