Quick welding ?
Discussion in 'The Garage' started by k5freak44, Jul 31, 2004.
  1. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    Is it safe to weld in new floor pans with a tank full of gas? What safety preautions should i take?
  2. tRustyK5
    Jul 23, 2000
    36,184
    1,392
    E-town baby!
    If you're worried about it drop the tank first. You could pack the top of the tank with sopping wet rags too, but when they dry out they'll catch fire which is even worse.
    I'd probably drop the tank.
    Always a good idea to have a good extinguisher handy. Make sure it'll put out a gasoline fire (water will make a gasoline fire worse)
    Prolly a good idea to have someone keep watch while you're welding too. You will not notice a fire while you're welding...
    Rene
  3. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    I wouldn't if you are directly over the tank or near the vents or fill tube...
  4. cybrfire
    Dec 15, 2002
    15,143
    574
    Iowa
    If you are at all worried about it drop the tank. In the end it will be your end if something goes wrong.
  5. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    I wouldn't risk the life of your truck, and yourself. even though the floorboard is a few inches above, the heat will still heat the tank up... so just drop it and be done with it.
  6. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I'd drop the tank, safer and easier. Besides, its not the gas that ignites, its the fumes.
  7. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I dropped the tank to weld the floors then ended up cutting all the floors out and it took about a year to get a tank back in /forums/images/graemlins/thinking.gif /forums/images/graemlins/histerical.gif
