quick wheel question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddysub, Jun 11, 2003.
  1. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    how wide a wheel should i run for a set of 38x15.50-17 or 16" parnelli jones dirt grips? oh this is on 1 ton gear and enough lift to easily clear them if that matters.
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I like 10" personnaly, but you could run 12" with no problem I am sure.
    -Brian
  3. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    a good rule of thumb is to have the rim width within 4" of the cross section of the tire. so a 12.50 on either a 8" or a 10". don't get to close for instance run a 12" rim w/ a 12.50 tire. it will look funny.
    to make a long story short i suggest 10" if u like the narrower look & 12" if u like the wider look. personnally i would go w/ the 10" rim.
  4. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    10" wide rims work great on my 39.5x15x15 TSLs. Unless you plan on definitely putting even phatter meats on at a later date, I'd go 10"...
    j
  5. muddysub
    Jun 23, 2001
    10,452
    489
    thanks guys!
