quick yes or no guestion
Discussion in 'The Garage' started by K5-newf, Mar 2, 2007.
  1. K5-newf
    K5-newf 1/2 ton status
    Nov 5, 2005
    236
    canada
    Can you got a 3/4 6 lug 2wd?? i just figured they were half ton or heavey halfs. And if so what would it require to do swap the front end.
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    Yes, 6 lug 3/4 aren't really that rare.
    Do you mean how much work is it to swap a solid front axle under a 2WD truck? Just buy a 4WD, its not like old Chevy's are expensive.
  3. K5-newf
    Nov 5, 2005
    236
    canada
    i meant can you get spindles/hubs in 6 lug for a 2wd drive truck
  4. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    depends on the truck 67-69 1/2 ton 2wd were 6 lug from the factory.
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Actually, 67-70 1/2 ton 2WD trucks were all 6 lug, 67-70 3/4 ton 2WD trucks came either 6 or 8 lug. These were all 4 wheel drum brake though. Starting in 1971 GM used 5 lug on the 1/2 ton with disc brakes and 8 lug on the 3/4 ton trucks with disc brakes.
  6. K5-newf
    Nov 5, 2005
    236
    canada
    Thanks you
