QUICK ZERO RATE QUESTION
Discussion in 'The Garage' started by 79Stomper, Nov 27, 2004.
  1. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    I am running a Rough Country 6" Lift onmy truck. Did anyone use their degree shim on the front when you moved your axle forward woith the zero rates? Quickest replies appreciated as I am knee deep in an axle swap right now.
    TIA /forums/images/graemlins/waytogo.gif
    James
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i moved my axle fwd 1.5 inches on 4 inch(i think) springs. i used 4 degre shims, BUT have yet to put the driveshaft on.
    so i guess im no help. the angle looks about right, but until i hook it all up i can say for sure.
    also it depends on what t-case you have, along with tranny and front axle. they all play a small part along with shackles as well. then you have to add in if you have dropped your t-case as well.
    grant
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Stacking shims on top of zero rates is not safe in my opinion.
