Quik torque spec please
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SuperUnknown, Mar 21, 2002.
  1. SuperUnknown
    SuperUnknown 1/2 ton status
    Feb 8, 2001
    165
    Prince George, British Columbia, Canada
    Could someone tell me if there is a torque spec for knock sensores. ('88 350) Thanks in advance.
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I found a spec in a 1994 GM truck service manual. It says 14 lb/ft for the knock sensor. It also says to only use a water based caulk for a thread sealant. Using teflon tape can prevent the threads from grounding to the block. That is what completes the circuit for the sensor, so you don't want to keep the sensor from being grounded.
