R&P & Detroit Locker Install
Discussion in 'The Garage' started by chiefheaphy, May 3, 2007.
  1. chiefheaphy
    chiefheaphy 1/2 ton status
    Mar 13, 2007
    632
    East MASS
    Anyone have any good links for this install.
    Which specialty tools are essential and witch can I do without?
    Anything in particular to keep in mind?
  2. dremu
    Feb 27, 2000
    15,958
    450
    East of San Francisco
    Helpful to know which axle.
    -- A
  3. chiefheaphy
    Mar 13, 2007
    632
    East MASS
    Woops
    60 Front
  4. johnnychimpo
    johnnychimpo 1/2 ton status
    Oct 9, 2005
    1,145
    Nash, TN
    Check the tech section on Pirate. Look for the D60 bible & a writeup on setting up the gears.
  5. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    yeah Billavista's D60 tech bible is AWESOME....
  6. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Are you replacing the gears too or just installing the locker? It is easier if you don't have to set the pinion depth.
    I would remove the bearings and shims from the old carrier first. Then install the shims on the detroit the same way they were on the old carrier and then put on new bearings. Bolt it all up and check your gear pattern and backlash. You might luck out and have it work out the first time. If not you will have to mess with the shims until you get it right.
    Tools would be a dial indicator with magentic base and a way to check the thickness of the shims. You also need a bearing seperator.
    If you are putting in a new pinion you need a pinion depth tool.
    I think Randy's has some more indepth instructions on their website in a .pdf format.
    Here is a link to randys with some good info!
    http://www.ringpinion.com/HowTo.aspx
  7. chiefheaphy
    Mar 13, 2007
    632
    East MASS
    all
    yeah im throwin in 5.38s and Locker
