R&P experts check here OK 1 MORE TIME TONIGHT UPDATE 3
Discussion in 'The Garage' started by MTBLAZER89, Jul 8, 2003.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    UPDATE#3------------------------------How is this even kind of looks like the drawings lol
    -------------------UPDATE #2-------------------------------
    Ok how do these look? Hard to compare to a black and white drawing lol. I thought they were pretty close....
  2. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Re: R&P experts read my patterns [PLEASE]
    Are you using anything to apply a slight load to the ring gear while you check the pattern? It makes the pattern much more noticable and it does look as if the pinion was a little shallow, although the driveside does still look as if the pinion is contacting a little to deep on the drive side of the second try.
  3. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
  4. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    pinion looks a little shallow it should be more towards the toe of the ring gear.
  5. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    TTT new pics and questions
  6. thefarside
    thefarside 1/2 ton status
    Jun 27, 2003
    343
    Vernon, CT
    Re: R&P experts check here (UPDATE) NEW PATTERNS
    WOW, you brave tring to install your own R&P!
    I think I would have a shop do it. That is just me though.
  7. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    he is brave, doing it right.
    i was just stupid. /forums/images/graemlins/laugh.gif
  8. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    ttt Anybody?? /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/ears.gif
  9. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Are you putting any kind of drag on the carrier as you turn the pinion?
  10. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    yeah...kinda wondering why I am getting two different patterns on the two different spots on the ring??
  11. TheLakeRat
    TheLakeRat 1/2 ton status
    Nov 29, 2001
    363
    San Angelo, Republic of Texas
    Your pinion is still too deep. add about .005 to .007 and repattern and then post again. you can send me pics direct if you want. I'll be online almost all night.
  12. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    cool thanks dude!! Why am I getting a different pattern on the two areas I pasted the ring??
  13. TheLakeRat
    Nov 29, 2001
    363
    Welcome to the hell of doing R&P installs. they will read strange things and sometimes will even make you think that you need to go in the oposite direction unless you know what to look for. Also if they are a used gear they will be a bit starnge to set up also.
    I try to take a pattern off of the gears before i pull them out so when i sell them i'll know where they were running in the old housing. I don't suppose you did that?
  14. dyeager535
    26,980
    IIRC, Randy's ring and Pinion states that most often, you will NEVER get a perfect pattern with a used set of gears, and that the coast side is less important especially with used gears. (hope I remembered that right)
    Have your experiences been different?
    I know full well the dangers of not setting the gears up correctly, did it once by just swapping carriers in the axles, then had to go back in and set it up correctly to get rid of the unbearable noise.
  15. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    My paperwork says coast side is MORE important than drive.
  16. dyeager535
    26,980
    I could have that backwards, it's been a few years. Just curious as to what was more important, because I remember that one side was specifically mentioned as more important in regards to used gears.
    As to another question as to why your gear pattern seems different when you turn the ring/pinion to the "other side", is there any chance you had to much of the marking compound on the gears by that time, and it's just not a clear pattern?
    I think I may have cleaned mine off every time I made an adjustment, "just in case" that was an issue.
  17. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Why would the coast side be more important then drive side?!?
  18. TheLakeRat
    Nov 29, 2001
    363
    It's not but they don't want you to concetrate on the drive side on a used set because it will be worn more than the coast side. So if you concetrate on the coast side and get that pattern correct then the drive side will automaticly be in the correct possition even if it doesn't look correct due to the wear pattern that it may have developed over time.
  19. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Well I drank too much tonight soooo that pattern will be run tomorrow /forums/images/graemlins/eek.gif
  20. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    New patterns..........[crosses fingers] Think I'm close.
    TTT /forums/images/graemlins/ears.gif
