r/r brake light on constantly
Discussion in 'The Garage' started by wraenking, Feb 26, 2005.
  1. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    when i turn my lights on, without pressing the brake pedal, the right rear brake (top one) light is on. i tried a new bulb. any pother suggestions?
  2. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    start checking for shorts in that rear harness... start jiggling em here and there.. you remember when mine where freaking out... the wires had fused themselves together behind one of the retainer clips that the wires run thru...
  3. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    i had the same problem and it turned out i put the bulb in backwards
  4. diesel4me
    Jul 24, 2003
    17,577
    945
    Massachussetts
    wrong bulb??
    If you put an 1157 bulb in place of a 2057,the filaments are reversed,and the brake light filament lights up instead of the "dim" one for the running lights..if the bulb is correct,check the wiring harness as already suggested--pay extra close attention to any trailer light plugs,a lot of problems with the tailights originate in a faulty or coroded trailer plug socket,or where the harness was spliced to install one...:crazy:
  5. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Try unplugging the big connector on the underside of the steering column. The brakes/turn signals/hazards all run through the turn signal switch. I had some really weird stuff going on when mine went out.
  6. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    ding ding ding, we have a winber.
    and i get retart of the month award!!!
    thanks boys
