R12 Freon.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JimmyJuneau, Aug 11, 2003.
  1. JimmyJuneau
    JimmyJuneau 1/2 ton status
    Apr 11, 2001
    811
    Juneau, Alaska
    Im not sure if my truck has R12 freon in it or not but Im guessing it does becasue its an 85. so does anyone know where I can get this or do I have to buy it from a mechanic? I live in Stockton Ca.
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    R12 is not for sale to the public. The system has to be recharged by a pro.
    That is unless you can find someone with some bootleg R12. I remember Kmart used to sell the stuff in 1 pound canisters and when the word went out people bought the stuff like crazy.
  3. BigBadJap
    BigBadJap Registered Member
    May 23, 2003
    76
    Alberta, Canada
    Here's an interesting DIRECT substitute:
    RedTek
    This product is a HydroCarbon (refined propane/butane) but it apparently used in about 50% of vehicles in Europe as a refrigerant without incident. The places I have found it cost $17 CDN, so probably $13 US.
    Lots of places here do not even purge the out r12 out, they just top the existing refrigerant up with this stuff.
    No conversion, o-ring safe, lubricant safe, relatively cheap.
    I haven't tried it yet, but I plan on it this week.
  4. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    On the air unit (under the hood, near the firewall) will tell you the type of freon to use. My 88 uses R-12, had it recharged (3.2lbs) for $195. Sometimes the cost of the conversion can cost the conversion to 134 can be the same.
  5. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    you cant get r12 readily anymore... the easiest way is an R 134a conversions...
    you need two new schrader caps, a few cans of 134 a can of lube and a gauge... should cost around 40 bucks
  6. 88Silverado
    Mar 13, 2003
    2,664
    Any Automotive Aircondition repair place has R-12.
    I called 7 different places locally here and got prices from $300 down to $185. The cost of R-12 has come waaaaaaaaaay down over the last few years. You cant buy it off the shelf but licensed businesses can.
    If your going to do the service yourself better have the gauges to do it. You need to evacuate the system, change the oil in the compressor, pull a vacuum to check for leaks (something is leaking if you need freon and didnt open the system yourself) then charge R-134 via guages. Fill about 80% of R-12 because 134 runs higher head pressure.
  7. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    They can't make anymore R12 in the US. But shop can use what is still in the pipeline.
  8. 88Silverado
    Mar 13, 2003
    2,664
    This is true, I believe the manufacturing stopped in 1995.
    It is estimated that several million pounds of R-12 are still stored in the US. It will take a few years to get rid of it. It does appear since the conversion of R-12 started, the usused supplies didnt dry up as predicted and the demand for it is down. Thats why the price of R-12 has actually dropped, theres not as great of a demand for it now and some suppliers are sitting on a lot of surplus and are getting concerned they will not have a market for it in the future.
  9. mrbill
    mrbill 1/2 ton status
    Jul 1, 2003
    170
    Sugar City, Idaho
    Just saw this in the Portland Or. Oregonian paper
    Auto Parts, Tires, Repairs
    FREON replacement R-12, 12 can case, $150. 36 lb canister, $275. 1-800-807-9612
    Published in The Oregonian on 08/10
