rachety / grinding noise - please help, I about to shoot the damn truck
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Goodolboy, Apr 15, 2003.
  1. Goodolboy
    Goodolboy Registered Member
    Mar 13, 2003
    6
    Utah
    I put a lift on my 87 Jimmy (full size). The truck ran great prior to the lift. The rear end started make a grinding rachety noise in the ass end when I decelerated. I put shims (6 degrees of angle)on. It seemed to help a little, but not much. I highly doubt anything is wrong with the rear diff (10 bolt) since it was fine before the lift. I'm would like some more ideas on what could be wrong. The angle of the driveshaft isn't that bad. Would an out of balance driveshaft cause this noise? By the way its a 10" lift. The front driveline is at a much worse angle and it operates great. I would appreciate any news thoughts. I have read past posts and they don't give me quite the help I need.
  2. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    try changing the u-joints...sometimes they make noise like that
  4. CrazyCoot
    CrazyCoot Registered Member
    Nov 24, 2002
    25
    Redding, CA
    10" on a blazer? No wonder you have a vibration! You may need to talk to these guys High Angle
    Lower the T-case and maybe a slipshaft eliminator.
  5. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    10" lift and a 10 bolt? mall cruiser eh? anyway, i agree with all of the above.... especially if you have a np208 tcase. If you want to stick with the 208, you'll probably have to lower it, and get good HAD shafts + the appropriate amount of shimming to make the bad vibes go away. driveshaft length is another thing to watch for on np208s because it has a slip yoke... you dont want to be wheelin and while you flex your rig the rear driveshaft drops out the back of the case into the dirt. /forums/images/graemlins/shocked.gif
    j
