rad size
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Paxx, Mar 14, 2004.
  1. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    would a 350 bored .060 over need a larger rad than a stock 350?
  2. 1989k5
    1989k5 Registered Member
    Jun 10, 2003
    36
    near Lake Superior, Wisconsin
    What is a rad?? If you mean rod, the answer is no. Your old rods will work, but I would have them checked. I always put in new wrist pins and even balance them by weighing all 8 and removing some material to match the lightest one. Also make sure you stamp your rods and caps so they are matched when you reassemble. I however would rather bore .030 or .040 over in case the block would ever need to be rebuilt later for a badly scorred wall or scratch. Good luck!!
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Or do you mean radiator? Run a big four core /forums/images/graemlins/thumb.gif
  4. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    A good 3 core should be plenty for a mild 350.
  5. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    I did mean radiator. My buddy is having some frusterating cooling issues and we are starting to wonder if the rad is just too small.
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    How does the gauge read. Sometimes too hot or too cold would indicate bad thermostat. When they stick open a little it may run too cold. If it don't open at all you'll overheat. I assume you already checked the easy things like belts etc? Are you running water , or a coolant mix? Also check the fan clutch if mechanical fan. If that isn't clutching the engine won't pull enough air to cool it . Hope these thoughts help. /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  7. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    hmm they do help. We have no thermostat in it right now just to simplify it a bit. The temp will stay fairly constant for short periods of time and then put of nowhere it will spike up to the danger levels. So then you stop and wait a while, drops down, cruise for a while, then it will spike again. Very frusterating. I'll get him to check the clutch. Is there an easy way to do this?
    thnx~Max
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    There are two styles of clutch. One is thermstatically controlled, there is a spring like a choke spring in the center, it should kick on when warm. The other style is centrifigal clutch , it has fluid in it, it works at lower speeds and slows down on the highway. I may be backwards on it, been so long since mine was bad. Someone should correct me if I have it backwards. Hope it helps /forums/images/graemlins/thumb.gif
    BTW you should run a thermostat, it will hold back the water so it can absorb the heat, then open and send it to radiator to dissipate it. May make all the difference /forums/images/graemlins/waytogo.gif
  9. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    The easist way to check the fan clutch from what I remember is to: try to turn it when the rig is cold and see how much resistance you have, there should only be a little resistance then. Then when the temp spikes like that and the truck is good and hot stop it and try to turn the fan right away again, it should be really stiff like your trying to turn over the engine. If it doesn't have any resistance then it's most likely bad.
    But you really need to stick a thermostat in there too, that will make a ton of difference too.
    If after all that you still have issues, get a large four core or a wide tube two or three core. I have a wide tube two core that supposedly cools as good as a normal 4 core. It does work a lot better than the original radiator, but I'd still like to run a large 4 core. /forums/images/graemlins/waytogo.gif
  10. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I agree, The water needs to be held back so that an actuall transfer of heat can take place between the cylinder walls and the water.
  11. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    thanks for the replies guys, I'll give all that a shot.
