Raddling shifters what do i do??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Chaz88K5, Dec 14, 2001.
  1. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    OK i just got to drive my truck today for the fist time without something goin wrong...well anyway my shifter on my 205 is raddleing like crazy...what do i do to fix that...is there a bushing kit i can get somewhere?...dose steven sell somthing?? its driving me freekin crazy...i need it fixed!!...help me
    <font color=green>Chaz</font color=green>
    [​IMG]<a target="_blank" href=http://community.webshots.com/user/chaz88k5>http://community.webshots.com/user/chaz88k5</a>[​IMG]
  2. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    Hey Chaz, just turn the stereo up!!!! Wheres the play in it? If i remember correctly, the one i have (on a th350 version) mounts to a big bolt, then the rod goes back to the shift rail, right? Maybe just a couple rubber washers between all the parts where they hook together? Just an idea. Or you could buy the 465 version 203 range case i have, then do the doubler, and get that cool twin stick ORD shifter i'm putting in. Come on, you know you want to!!
    Leland aka RaisedK5
    "Of all the things I've lost, I think I miss my mind the most!"
    "Are the voices in my head bothering you?
  3. Chaz88K5
    2,979
    Stockton/Lodi CA
    yea its on the bolt where it is loose...i already have the 203 adapter and the 203 gear box so all i need is the ORD kit....BUT (there is always a but) i am really short on fundage...not goin to have a job after the first and turnin back into a full time student...so i am goin to be broke for a long time to come..i guess i will get some brass and make a bushing on the lathe...i havnet used a lathe since HS so this could be interesting..
  4. dyeager535
    26,975
    So if you grab the shifter handle the noise quits? Theres a thin wave washer that goes in between the adapter and the shifter handle, on the bolt, that is missing on mine, and mine makes a somewhat high pitched rattle as it vibrates, at all speeds. If I grab it, it goes away. I'm sure adding that THIN (or else the bolt will loosen up) wave washer will solve MY problem.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  5. Chaz88K5
    2,979
    Stockton/Lodi CA
    i think that is in there...but i am goin to check tommorow..it almost seems like its stuck inbetween 2 and 4wd...but the front shaft is not turning...but on my way home from work today i had another problem...it got stuck in 3rd gear again and will not come out...so i had to slip the clutch like crazy to get rollin from a light....it dident work well...couldent have been good on my clutch...but looks like it goes back in monday
  6. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    BTW...got a nice pic of you wedged into that hill you had trouble with out in Hollister...lol. Anyways...GM actually has the answer...when i bought a new NP205 shift stick from them this year to swap the Chalet over i was shocked when it came out of the box....it now has a big rubber spring type bushing where the bolt goes thru...no noises here!
    Azblazer
    1979 K5 350 TBI
    1976 K5 Chalet
    If it ain't got arizona pinstriping.....you ain't wheelin the pee outa her!
  7. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  8. EDdaTREE
    EDdaTREE 1/2 ton status
    Feb 18, 2000
    1,253
    Austintown, OHIO
    I know there was a post about this on NP 203 shifters...a couple of 2 cent nylon washers from the hardware store solved it. Copper or brass is the 2nd option....
    9/11/01..Never forget...Never forgive
  9. Chaz88K5
    2,979
    Stockton/Lodi CA
    AZblazer...you wouldent happen to have the part# for the shifter would ya....i kinda broke mine while trying to bend it...i welded it back together but i would like to get another one...and then it would also take care of the worn out joint.
  10. K5 NUTT
    1,611
    Been out and about all weekend..will dig thru my file tomorrow or just open my RV parts book..all Numbers seed to the new one.
    Azblazer
    1979 K5 350 TBI
    1976 K5 Chalet
  11. K5 NUTT
    1,611
    Group 4.570 (87-90 K30) #3 LEVER, Trfer Case Control PN# 15548975...the late model Knob Assm is PN# 15648946...and the boot PN# is 14071955.
    I didn't use the stock linkage...used 2 hiem joints from work. Some of the older t cases had the link welded to the shift rod...also you can get the new new nut for the lever which has a threaded hole allready in place for a grease zerk.
    Azblazer
    1979 K5 350 TBI
    1976 K5 Chalet
  12. Chaz88K5
    2,979
    Stockton/Lodi CA
    thanks
