Radial and Bias on same axle
Discussion in 'The Garage' started by Jishory, Jan 25, 2006.
  1. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    So I was wondering the other day while doing this why im not supposed to run a radial and bias tire on the same axle (I didnt go faster then 25mph). Anybody know?
  2. diesel4me
    Jul 24, 2003
    17,545
    936
    Massachussetts
    not good!
    They both handle SO differently from each other,it can cause loss of control at highway speeds over 35 and up..if you MUST "mix" radials and bias ply tires,put the bias ply's up front..
    I tried using some bias ply studded snow tires on my van I had hanging around in excellent shape..figured studs would be nice in the snow..I put the all season radials up front,studs in the back,and went for a long ride to visit my brother up north..I did fine until I got onto a wet highway onramp...at 35 mph,the vans ass end suddenly started passing me!..I did a 180,and came to a stop up against the curb,in the blink of an eye..:eek1:
    I had felt a strange feeling like the front and rear were fighting each other just before the ends swapped..I ended up using the studded tires in FRONT on my long ride instead!..I found it drove ok at high speeds,but did feel "squirmy"..traction wasn't a big problem in the rear in my van,it had lots of stuff in it and was heavy..the studded tires up front actually helped a lot as far as steering..but I took them off as soon as I got home,and put 4 radials back on..
    I'd avoid mixing the 2 types..using just one bias ply out of 4 might not be so noticeable,but I can safely say if you put 2 of them on only the rear axle,you'll be doing doughnuts...especially bad on snow or ice,or even wet asphalt..:eek1: ..
  3. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I have 4 BFG MT's and one HMMWV tire on my truck and can't tell the differance any more. The biased tire was noticable as it pulled to the side at first. not too bad though
  4. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    Strange 5 wheeled truck?:confused:
  5. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    :haha: :haha:
  6. readymix
    May 30, 2004
    6,706
    26
    damn you all, it's too early.:haha::haha::haha:
    I not even going to edit it as it is funnay:rolleyes:
