RADIATER HELP NEEDED
Discussion in '1982-Present GM Diesel' started by doctor4x4, May 11, 2002.
  1. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    any body got the part nu for the lower radiater hose when you use the diesel radiater and a 454 regular long shaft water pump my problem is the output on the pump is a little smaller then the input pipe on the radiater so i get this f*#*#g little drip :-( any help would be much appricated
    Thanks once in a while even the doc needs help :-)
  2. 4x4_76
    4x4_76 1/2 ton status
    Jul 22, 2001
    628
    Ylämaa, Finland
    I have gasser radiator on my K5,untill I find one for 6.2.
    It has smaller water necks than diesel rad,so I took gassers radiator hose and cut a short sleeve from it.The I just slipped it to a lower water neck,radiator hose over that,and tightened the clamp.So far,no leaks.
    Upper hose I had to make from a 5.7DX lower hose because gasser has narrower radiator than 6.2D,and because of that,couldn't use upper diesel hose.
  3. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    If the difference is only a few millimeter, there are special hose clamps for it, which wedge at their entire extent. Ask in your tool shop.
