Radiator brackets
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Smitty, Feb 17, 2001.
  1. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    I ran across a deal on a new 4-core radiator today. Picked it up for $155. Only problem is that this one has 3" tanks and my old radiator had 2 1/4" tanks. Everything fits except the brackets. I found the right size rubber spacers for the bottom but am having problems finding the right size brackets to go from the radiator support to the radiator tanks. Anyone have any ideas where I might find some? Figure something with a 6.2 might have something that will come close but not too sure.
    Smitty
  2. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    Looks like I found the info I need in another post from BigBurb. I'll still hit the junk yard tomorrow and see if I can find the brackets in something.
    BigBurb, thanks for the post with the part numbers!
    Smitty
  3. dyeager535
    26,978
    Yeah the 6.2's might work, they might be too wide though, there were some wide diesel ones. You can still buy the upper radiator support (one piece on the big radiators) and the BB fan shroud which I believe you need for the very thick radiators. Since you said you got numbers from bigburb, assuming they are GM numbers, go to http://www.dorianyeager.com/index2.html
  4. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    Thanks for the heads-up on the web site!! I'll check it out tonight.
    Smitty
