Radiator dimensions
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by k5james, Oct 11, 2006.
  1. k5james
    k5james 1/2 ton status
    Feb 25, 2004
    792
    San Diego, CA
    Can anyone give me the radiator dimensions of the stock radiator? Also, the dimensions of the end tanks would help as well. I want to check them against the dimensions of mine before I give the info to Ron Davis for my aluminum set up.:D
  2. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    I will try to measure tonight. Does it matter if it is a 3 or 4 core, I can get measurements of either.
  3. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Here are the dimensions from my 4 core replacement radiator I'm using in my 69 K20.
  4. k5james
    Feb 25, 2004
    792
    San Diego, CA
    Awesome man, thanks. I appreciate it.
  5. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    i just dropped my 80s style 4 row into my 71 and bam... too tall. Not to hijack too hard but I have a shorter 3 row that will fit. Did they make a 4 row that is the shorter style?
  6. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Yep, 1st Gen 4 core. I have one sitting in back, and it is the same as my 2 core.
  7. MNorby
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    anmd it looks like no way the taller 80s style 4 core will fit? Doesn't look like it but thought maybe someone has adapted. Just need to find someone to trade. Any aplication the 4 rows that were common in? big block gen1s or something
  8. 3 on the tree
    Oct 16, 2004
    3,970
    gunnison colorado
    3/4 ton and up. A bunch of Burbs had the 4 cores also. Mine came out of a 68 K20. 1/2 tons also had them but I have seen more on the larger trucks.
  9. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,962
    251
    Released from Pueblo, told I belong in Southpark
    You can also order new 4 core that fits and then just get the wider supports from LMC. 2 on the bottom and the two on top. My radiator was a little less than $200.00 Milodin (spelling)
