Radiator fan blades
Discussion in 'The Garage' started by lochenjons, Feb 3, 2007.
  1. lochenjons
    lochenjons 1/2 ton status
    Sep 13, 2006
    682
    Santa Cruz, CA
    I have to replace mine (shroud was missing a bolt and fell down and bent all the blades...right as I went into a mudpit...I got video too :haha: Ill post it up later) so I'm gonna go down to the picknpull tommorow. Do I have to torque down the bolts that hold it down or just get em tight? Gonna fix that shroud to :D. The pathetic thing was I knew it was missing the bolt so I had tried pushing down the shroud to see if it'd go anywhere and it wouldnt go down far enough to hit the blades so I figured i'd be good untill I found the bolt...ha obvioulsy not :doah:
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Man , I have like 7 or 8 fan blades lying around , someone was actually going to toss em out , and I saved em .
  3. blazin_blazer
    blazin_blazer 1/2 ton status
    Aug 2, 2005
    4,043
    central arkansas
    i have alot of fans also, i ussually try and find the 7 blade stock fans instead of the 5 blade fans. also on my mud runners i take the fan off and use electric fans, so its not spraying water all over my engine bay.
