RADIATOR HELP!! ASAP PLEASE!!!
Discussion in 'The Garage' started by BowtieRed, Nov 5, 2003.
  1. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    part of the fan shroud on my new POS shot into the radiator and it now leaks from a line running across the vents. can this be repaired? or do i need a whole new radiator?
    thanks,
    red
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Any radiator shop could solder that back together, no problem.
  3. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    how about if i, temporarily, pull the cut line out of the venting, cut the ends, and use some small rubber hose and clamps to connect it back together?
  4. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    It might be a better idea to pinch it all together real tight so that the leak is as small as you can get it, and then put in some radiator stop leak. That barsleak is amazing stuff.
    The hoses may not seal well. Since the ends are not barbed, when it gets hot and the radiator tries to pressurize, it could push off a rubber hose.
    I fixed a radiator out in the sticks once by pinching the hole together and gobbing it with silicon. It worked too.
    Good Luck.
  5. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Yeah try that barsleak stuff. We use it all the time at the shop if its a small leak. It works wonders. /forums/images/graemlins/thumb.gif
  6. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Back in High School we changed a water pump once and forgot to put in the gaskets. We didnt want to tear it all apart again. Two bottles of that stuff and it lasted for a few years. /forums/images/graemlins/grin.gif
  7. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Yup we use it all the time. Its such a wonderful color too /forums/images/graemlins/rotfl.gif But if you use be sure to shake it up real well BowtieRed.
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    what vents you mean ? im confused ??
    hum...
