Radiator hose necks
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RedDwarf, Jul 22, 2002.
  1. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Ok, this is complicated (I think)....
    I had a 74 truck. The radiator had the "big" upper hose neck (I think it's 1 7/8")
    I swapped trucks, and radiators. The new Rad had a 1.5" upper hose neck on it (I think most of the 81-87 trucks do?)...I had it changed to the bigger size at the Radiator shop....
    Well, I got a new 4 row, BRAND NEW
    It has the 1.5" upper hose neck on it. What do I do? Can I get a new thermostat housing, or do I just need another hose?
    I hate to have them put a different neck on there, it's brand new....
    TIA
  2. RedDwarf
    May 9, 2001
    816
    Anyone?
    Did I word it wrong??
  3. ol_grayfeather
    ol_grayfeather Registered Member
    Jan 15, 2001
    68
    Around Spokane, Washington
    What I've seen people do is take a small chunk, about 3" or so, or the smaller hose and put it inside the larger hose. From what I remember the small hose fits perfectly inside the larger one.
    Dan
  4. RedDwarf
    May 9, 2001
    816
    thanks, I wondered about that too...reckon it'll leak? Should I put some kind of sealer in there?
  5. ol_grayfeather
    Jan 15, 2001
    68
    I guess if it leaks you could try some silicon sealer but theirs never leaked. Just make sure the hose clamp is snugged up.
    Dan
  6. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    I really dont see why you couldnt just swap out the thermostat housing, they usually dont cost that much. Go down to the auto parts store and compare a newer one to the one you have.
  7. RedDwarf
    May 9, 2001
    816
    Ok, that sounds like a plan.
    Guess I'll do that first.
