Radiator install
Discussion in 'The Garage' started by socal chevy, Nov 9, 2005.
  1. socal chevy
    socal chevy 1/2 ton status
    Nov 18, 2004
    308
    San Clemente, CA
    I want to buy and install my own....Is it simple? Anything to watch out for?... How do you drain the radiator?... Any other tips?
    Thanks.
  2. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    kindof a noob question but thats ok. Their should be a pet-cock(sp??) at the bottom left or right of the radiator facing the rear of the truck. If you cant find it just pul the lower hose off and have the drain bucket ready. As for the simplicity? it doent get much more simple. just pull thehoses off, pull the tranny cooler lines off (their will be two i think they are 1/2 " wrench) then pull the bolts that that hold the bracket that holds the radiator and possibly need to remove fan shroud bolts. as for stuf to look out for? theire isnt much to look out for just check the condition of your hoses and if they are no good replace them they are like $8 a hose or somthin like that. and get a new radiator cap if it doesnt come with one. thats about it any more questions, just let me/ us know good luck
  3. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    not noob if ive never done it. =) Thanks... I was just making sure.. AFter all removing the dissy is easy right?.... WRONG. Once you get it out you gotta get it in! I found that out the hard way.
  4. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    I ordered a aluminum radiator from summit racing. Its a summit radiator 31" x 19" 2-core radiator. My stock radiator thats in there now is 34" x19". Will the new summit radiator work ok?
  5. MrArmyAnt
    MrArmyAnt 1/2 ton status
    Dec 29, 2004
    662
    Texas, Kick a$$! (Grapevine, DFW; also Norman, OK)
    Hmm, with jimmy rigging it should, wished you had gone with three core...
  6. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    WHY?... Aluminum cools good they told me.
  7. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    Aluminum cools good, yes. But that radiator isn't a perfect size swap. Plus, image that each "core" is a single thin radiator. A three core radiator is thus thicker and cools more. Now a two core cools less. But aluminum cools more. You probably didn't gain anything, although a four core probably would have been best. I think that's what they were getting at. All that money on some bling, and you really didn't get that far away from stock.
  8. MrArmyAnt
    Dec 29, 2004
    662
    Tis true. I dunno what I'd do, I need to go to a junkyard soon to see what I can find, never bend and supposedly dfw has some pretty nice junk (looking for a 14 bolt), also looking for rads as well. want a few on hand.
  9. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    It cost me 160.00
  10. guido666
    Feb 16, 2005
    788
    Longmont, CO
    That's not too bad then. I retract my former statement about the bling. It still is probably only thermally equivalent to stock though, and watch out for corrosion.
  11. MrArmyAnt
    Dec 29, 2004
    662
    Oh make sure all inlets/outlets match up then. and yes good price. I was looking at the racing type one for 500.
  12. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    corrosion would be a bigger problem on a stock-type radiator than an AL one. Also, most all AL ones I have seen use hella-larger tubes than stock rads... if it doesn't cool better than stock, something is probably wrong. All about surface area, right?
    j
