Radiator leak
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Biggedraws, Aug 8, 2001.
  1. Biggedraws
    Biggedraws Registered Member
    Apr 13, 2001
    57
    Gilbert, arizona
    I have a 350 TPI and the antifreeze is leakin badly... isee where its coming from it looks like its coming from the place where the upper hose connects to the TPI any ideas on how to fix it? it doesnt look like its the hoses that are leaking.
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Do you mean into the intake manifold? That is where the t-stat is. It could be leaking from there. If that is the case a new gasket should do the trick.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
  3. Biggedraws
    Apr 13, 2001
    57
    Gilbert, arizona
    Im not sure what its called :( i dont know much about motors im only 16 it looks like its coming from the piece that connects the pper hose to the TPI its like a tube then turns 90 degrees and bolts to the tpi
  4. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Sounds like your problem is with the thermostat housing. I'd guess that the gasket is bad, but for about $10 more, I'd put in a new gasket, thermostat, and a new housing. Use a bunch of Permatex #2 non-hardening gasket sealer on the new gasket, and torque it evenly.
    Dos mas Tecates!!!
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  5. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    I agree with Pugsley, but just want to reiterate torquing it evenly is very important. I broke an ear off once in a rush on a sunday night (no parts places open). Got nowhere real fast!
    Ratch
    &lt;a target="_blank" href=http://k5.8m.com&gt;k5.8m.com&lt;/a&gt;
    **Your ad here**
  6. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Me too! I broke an ear off on my old dually's 454 in Monahans Texas on a Saturday night - it was a long wait till Monday morning to get a new one.
    Dos mas Tecates!!!
  7. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    LOL, story of my life... At least I was home, though. Sucks worse to have it happen away from home!
    Ratch
    <a target="_blank" href=http://k5.8m.com>k5.8m.com</a>
    **Your ad here**
  8. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Ever since that trip I've added a spare housing to my parts box - Pretty soon I'll be better stocked than most of the chain parts stores[​IMG]
    Dos mas Tecates!!!
