Radiator Leaking
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Calclips, Feb 4, 2002.
  1. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    I have a leaky radiator, can these be fixed or will I have to purchase a new one. It leaks from the left hand side, not in the finned area but from the edge area.
  2. greg83k5
    greg83k5 1/2 ton status
    Nov 2, 2001
    230
    space sity houston, texas
    do you HAVE to replace it?
    not if the barrs 'stop leak' stuff or the equivalent from the auto parts plugs up the hole, or you get real comfortable with adding water all the time.....
    our radiators are fairly common, go to the radiator shop in your area ( i bet you've been dying for an excuse to drop in ) and see what it would cost for them to set you up with a new one.... or fix yours
    mine was like 75 dollars.....
    greg
    * keep the greasy side down *
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Pull your radiator out, and take it to a rad shop. They may be able to rod it out, and repair the holes, if not then they can get you a new one.
    My Chevy isn't broken, its just out of gas.
  4. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    It sounds like the seam is seperating.
    I soldered mine a few years ago and it is still holding.
    Just be sure to use acid core solder on radiators, not rosin core.
    <font color=green> Too bad ignorance isn't painful </font color=green>
