Radiator mounts
Discussion in 'Center Of Gravity' started by crwln73, Dec 12, 2003.
  1. crwln73
    crwln73 1/2 ton status
    Sep 6, 2002
    362
    Clovis,Ca
    I need some ideas on how to mount my radiator now that the front clip is gone including the lower radiator mounts.Heres some pics
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Clicky no worky /forums/images/graemlins/frown.gif
  3. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    I originaly made a cage fr my radiator, then just tie it to your fire wall via a couple of tubes, if ya get real creative you can tie the whole mess into your roll cage, I have been thinking about this ALOT /forums/images/graemlins/thinking.gif
  4. cornfed
    cornfed 1/2 ton status
    Oct 15, 2001
    295
    washougal wa
    Yeah this is all I did - Im gonna try and get the radiator mounted today. I ll probably use some channel with thin rubber to support the radiator top and bottom and bolt the top ones down to tabs on the hoop.
  5. crwln73
    Sep 6, 2002
    362
    Clovis,Ca
    I ended up doing just that.Except I had to use a piece of 2x4x.095 and cut the top out of it.The 4in channel was tapered on the inside, so the radiator wouldnt sit all the way down in it.Just used the factory rubber on the bottom it fit perfect into the tubing.
  6. Stephen
    Sep 15, 2000
    4,228
    144
    Carbondale Colorado
    I've been using rubber window shims to insulate/isolate my radiators, apparently it works pretty good. We haven't broken a radiator yet. We try to stack the rubber to where it supports the radiator over a large area and where it's got some structure to it (near the tanks). It sits in a full channel or a pair of short channels. Then the top gets a clamp system similar to the factor setup with similar rubber isolation.
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    rubber window shims
    Hmmm, not sure what that is...
  8. CK5
    May 19, 1999
    21,627
    704
    CO
    rubber window shims
    You know, shims that go under rubber windows...
  9. Stephen
    Sep 15, 2000
    4,228
    144
    Carbondale Colorado
    Man you guys are out of it, haven't you heard of the new rubber windows, it's all the rage on....
    Oh wait, you can't have a rubber window! How would you see?
    Our shop is next to a glass shop that sets a lot of custom windows. They use hard rubber shims under them to isolate the glass from the house and they come in 1/4 and 1/8" thickness. They usually have big boxes of them sitting around so that's what we use. I don't know any other place to get them, maybe a good hardware store or a home depot type store?
