radiator on an s-10
Discussion in 'The Garage' started by 87BrnRsd, Feb 26, 2007.
  1. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    My friend needs his radiator replaced on a newer (1998-ish) s-10 blazer. He doesnt have the cash for the dealer to do it so I offered to help. I have never worked on the newer s-10's before and I am wondering if there is anything that I need to know before we start. Radiators arent hard...but is there anything on this newer s-10 that I may not know about or may give me trouble? Thanks.
    -Harrison
  2. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    just the oil cooler lines, they have a little spring clip holding them in, other than that, it should be pretty straight forward.
  3. 87BrnRsd
    Apr 21, 2003
    2,457
    Thanks for the help. Whats the trick to the spring pins?
    -Harrison
  4. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    294
    Truckee, CA
    Also, if there is Dex cool coolant in there, DO NOT MIX it wiht regular. Get a coolant that is compatible wiht both (certain prestones i think, it will say) and its pretty foolproof.
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    a pick or a screwdriver. There is a special tool that doesn't require removing them but its $100 through Mac. Local dealer should have a few of the clips in stock if you break, distort(I almost always distort them), or lose some.
