radiator over flow
Discussion in 'The Garage' started by shaun, Nov 19, 2004.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    Another issue I am having is my radiator keeps spitting alot out of the overflow? What would cause this? It is a new thermostat (160), a new water pump, 6 month old radiator, new hoses. What could cause this?
  2. tree_entz
    tree_entz 1/2 ton status
    May 4, 2004
    141
    N. Vermont
    just to clear the basics....
    how hot is your motor running?/forums/images/graemlins/thinking.gif
  3. ksblaze83
    ksblaze83 1/2 ton status
    Sep 11, 2004
    329
    Topeka, KS
    couldn't it be the cap???
  4. shaun
    Apr 22, 2003
    745
    My motor is running at a steady 168. It never tops 170. Justin it could be the cap and that is what I am going to do next. I think I will try and get a 18 psi cap to raise the boiling point from where my 16 has it?
  5. shaun
    Apr 22, 2003
    745
    Well the MK here at the station just explained to me exactly how a cap works and now that I understand that I think you are right on justin. I am going to put a new cap on it (probably just another 16 psi) tonight and see if that fixes my problem.
  6. tx_sub
    tx_sub 1/2 ton status
    Mar 5, 2004
    548
    Denton, TEXAS
    i you have any air in your system still from your recent work, the air will expand and spit fluid out. if so you need to bleed the cooling system
  7. whiskey bent
    whiskey bent Registered Member
    May 24, 2004
    49
    Alabama
    Sounds like a faulty cap.
  8. shaun
    Apr 22, 2003
    745
    I have already blead the system. I am thinking faulty cap also
  9. azblazer69
    azblazer69 Registered Member
    Jul 10, 2004
    30
    Phoenix, AZ
