Radiator overflow tank
Discussion in 'The Garage' started by BadDog, Sep 4, 2003.
  1. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    The front of my truggy is now about the same width as the radiator. And there are no inner fenders. Just the frame rail and the cage bar beside the hood. Not much room for an overflow tank. I need one that is about 2-2.5" diameter, maybe 10-14" tall. Basically tall and slim. I'll probably just build one, but are there any OEM or aftermarkets that will work?
  2. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    This sounds like a job for plumber man...dun dun da!
    Get yourself a piece of 2" CPVC pipe the length you need. It is designed to handle hot liquid. Cap both ends, drill holes in the top end to mount fittings and whammo you have a rad puke tank made to order.
  3. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,602
    554
    Wasilla AK,
    Summit i'm pretty sure they have small ones like that
  4. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    i second what gravdgr said. i've had that setup in my blaze for about 4-5 years. never had any problems with it. I'll see if i can post a pic tonight.
    ARQ.
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    But what about the *BLING*, you guys know I'm all about the bling! /forums/images/graemlins/smirk.gif
    I had thought about the PVC, but was concerned about it breaking with the vibration. While I was out running erands, I started thinking about copper. I wonder if I could find a piece of, say, 2.5" copper with copper caps and solder them together. Then add a tube run from top to the bottom for the hose, and a double elbow for overflow, and that should work nicely. Question is, can you find 2.5" x 12" copper stubs and caps... and if so, where...
  6. rcpilot
    rcpilot 1/2 ton status
    Feb 22, 2002
    507
    Central Cali
    ARQ.
    I'll second what ARQ said/has.. I saw it last night and now I'm building myself one /forums/images/graemlins/thumb.gif
  7. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    summit search for part number SUM-300101. looks like it may fit the bill, its $40.
  8. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Hmmm, how would that work? No vent...
  9. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    you know i didnt even notice it wasnt vented, but apparently it must work because summit only has 2 that are vented, pn's STF-5110 and STF-5115, are the ones that are vented. heres all the overflow tanks.
  10. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Yeah, I saw those. Not crazy about them though. I'm thinking it must be for a sealed system. Easy enough though to epoxy an open vent/overflow on the back side I guess. I also wonder if the tube goes to the bottom in that thing, assuming it is for a closed system it might not work right. Hmmm...
  11. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Ok, just called summit. Those are *just* catch cans, no recirc. They have those too, but much higher. However, these are threaded on both ends with standard NPT bungs. Sooooo, put the nipple on the bottom for the radiator line, another nipple on top with an elbow to direct hot water down, and you have a nice system for cheap... Too bad it's back ordered. I generally prefer to make all my own stuff, but I'm running out of time and this might be a good way to go.
    Plus... IT'S GOT THE *BLING*! /forums/images/graemlins/rotfl.gif Putting that on my junk is kinda like putting chrome shocks on a clapped out dump truck...
