Radiator question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CaveBlazin, Sep 13, 2003.
  1. CaveBlazin
    CaveBlazin 1/2 ton status Premium Member
    May 21, 2002
    1,348
    Middle TN
    Im getting ready to put the 406 in finally but I need to get me a radiator. What year and model blazer should I ask for if I want to 4 core one. I hope this makes since. I have a manual tranny just so yall know. Thanks in advance
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Go to Autozone and tell them you've got an '84 Chevy truck K10 1/2 ton 2wd auto trans with standard cooling and you can get a 3 core for $150. That's the one I've got. The manual trans one is $167 for the same 3 core. A 4 core is $240 and will be listed on the same page as a, "Heat buster". I think the 3 core is plenty. All of them will have a lifetime warranty.
  3. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I got a Modine #730...That is the listing for a 1987 K30 with a 454. Even though I have a MT, I got a rad for a truck with an AT so I can use the tranny cooler fitting fo stuff like PS fluid or oil...oh you will need to buy/make/borrow/steal 4 new rad. cushions for a 4-core...
    Chris
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I recall having a hard time finding reasonably priced 4 core applications, so I bought the 3 core.
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    give http://www.radiator.com/ a try i know a few people have gotten radiators from them and have been very happy with the price and service /forums/images/graemlins/thumb.gif
  6. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    Will a 3 core be cool enough for a 406???
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Sure, it'd be plenty. Airflow is more important than a thicker radiator.
  8. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    if its new or FREE FLOWING then yes if its not free flowing then no
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Even a 7 core radiator isn't going to cool if it's clogged.
  10. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    i got mine from radiator.com last year and i haven't had a single problem with it yet./forums/images/graemlins/thumb.gif
  11. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    Ok so yall twisted my hand I'll check into the 3 core deal and its cheaper. Thanks /forums/images/graemlins/thumb.gif
  12. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    Wow hey thanks Shannon I found a Radiator for 120 and its a 3 core from Rad.com thanks again for the help to all.
    Spence
  13. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    glad i could help /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  14. Grim-Reaper
    7,385
    Atlanta
    88 454 had external oil cooler and it's a 4 core. I just bought one. www.Radiators.com and www.raditor.com both have the modine for around $170 might get a discount with one since your a member. Check the venders list.
  15. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I have a built 406 and my 3 core is enough, but just enough. I have to watch the temp when I'm pulling hard in the mountains when there isn't a lot of air flow. I would suggest an aluminum rad. they cool better than a 4 core and are cheaper.
    85K5 3/4ton,14boltFF,10bolt,9"lift,35"boggers,16.5x14welds, big horse 406SBC/700R4 /forums/images/graemlins/k5.gif /forums/images/graemlins/angryfire.gif
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You said it yourself, "There isn't a lot of airflow."
    Use the right fan and you won't have cooling problems. Air conditioning makes it worse too, but I'd bet that a 3 core could even cool a 454 without A/C in the hottest of weather with the proper airflow.
    The proper coolant mixture helps as well.
  17. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    Its so nice to be a member /forums/images/graemlins/thumb.gif
  18. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    [/ QUOTE ] I have A/C and even in 100degree weather in stop/go traffic it usually doesn't get much higher than about 200 degrees. I JUST have problems in the mountains with a heavy load and warm weather. Otherwise it runs about 160 degrees.
  19. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    theres a radiator discount online store that sells new 4 core for 73-up for 150 bucks
    i was just looking at it the other day by accident, id have to search again to find it
    anyone happen to know where an 89 G20 van 5.7L auto trans radiator is at thats not internally cracked, a friend fo mine has such a van and tranny fluid is in his radiator fluid big time
    too bad one of my 77-79 van auto radiators would fit it, i have tow nice four core ones,
    thanks
    http://www.carradiator.com/radoptions.cfm?carengine=7.4L%2C+454ci%2C+V-8&carmake=CHEVROLET&carmodel=C%2FK%2CR%2FV+SERIES%2C+SILVERADO+PU&caryear=1982&x=41&y=30
  20. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Ahh, A/C is your reason for needing more radiator then. /forums/images/graemlins/smile.gif
