radiator repair
Discussion in 'The Garage' started by bigbadchev84, Mar 17, 2006.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    i got a small pin hole leak that leaks a good amount of antifreeze when warmed up, what is the best way to go about fixing it? i refuse to go to the only radiator shop in town because i wil not support his business, he is a ripoff. so what is the best solution to my prob? it is in the top corner and is one of the cooling tubes that runs side to side. thanks
  2. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    You could just mail order a radiator, then send your core back to them after the install. It's an extreme option, but it's an option.
  3. barneybasher1010
    barneybasher1010 1/2 ton status
    Sep 25, 2005
    908
    PORTERVILLE CA
    if it is small i would use bars leak i used it the other day with good results. It is also cheap
  4. 1985_K5_Silverado
    Dec 21, 2005
    984
    Corn Country
    Then again, Kennewick is about a half-hour away, and they're bound to have a shop or two that can patch the leak. You could pull the rad, take it to Kennewick in another vehicle, get it fixed, bring it back, and install.
  5. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Clean it and JB Weld it.
  6. fasthumpman
    fasthumpman Registered Member
    Oct 22, 2005
    85
    Texas
    black pepper. works really good
  7. JSH
    JSH Registered Member
    Oct 20, 2002
    75
    Iowa
    Clean it and solder it.
