Radiator Shroud
Discussion in 'The Garage' started by shanemcg45, Mar 12, 2005.
  1. shanemcg45
    shanemcg45 Registered Member
    Feb 7, 2005
    78
    Lubbock, TX
    Are radiator shrouds that neccesary? I'm putting on ORD's 1" body lift and I was going to Sawzall some of the bottom of the shroud off but then I started thinking about just taking the whole thing off. It's a DD so would it cause any problems?:confused:
  2. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    The shroud acts as a tunnel so to speak to force cool air towards the radiator. Taking it off kills the effect and can make you run a lil warmer.
  3. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Yes, he is correct. The shroud makes sure that the air flows *though* the radiator. I wouldn't take it off.
  4. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    if you have a 2pc shroud, just put in some spacers and space the bottom down,if its a 1 pc, trim as little as possible, i had to cut alot off mine, doesnt heat up, but if keep as much of one as you can. Plus looks better than a fan stickin out there by itself, and keep your hands out of the fan, and a good place to lay tools to forget them.
  5. AkMudr
    Dec 30, 2004
    917
    Alaska
    I did that to one of my f**d's a while back and 3 weeks later I blew a head gasket, not sur eif they are related but I do remember runnin warmer.
  6. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Another thing to consider would be the Winstar fan conversion. I would never go back. In fact, I wish I had done it a lot sooner. I get MUCH quicker warmups, and my temp is a lot more consistant. I haven't had to worry about engine temps ever since then, and I use to have to worry all the time. Since you just mount them directly to your radiator, it doesn't matter where the engine is.
  7. sweetk30
    Nov 1, 2004
    25,544
    539
    horseheads , ny 14845
    i had my old truck setup with built 400 sbc ( hot running motors) and th350 . with 1 ton 4.10 axles and 38 TSLs . pulled my friends truck down the highway at 60-65 dead tow and sat at 210 all the time. and when not in working it 210 all the time. put shroud on and might have droped 5-10 deg at most. this was with tall rad and 3 core. all on a long bed truck that tiped the scale at about 6500 lbs.
    i took the stapels out and seperated the 2 halfs. then i took some plastic h20 tube from hardware store and cut 6 pieces 3" long. then drilled 3 hole per side and got long bolts with nylock nuts so thay wouldnt vibrate loose and or crush the plastis. put all together and filled the gaps with some thin aluminum, from my friends house remodel job (window flashing). cut 2 groves to clear the core support at bottom and reatached it and fit great.
