Radiator Size: does it matter?
Discussion in 'The Garage' started by 91VJimmy, Dec 20, 2004.
  1. 91VJimmy
    91VJimmy Registered Member
    Dec 20, 2004
    11
    Brookings, SD
    Hi all,
    I have a '91 Jimmy (like the sn says) and need a new radiator. There's a leak at the top that sprays a light mist of coolant into the fan shroud.
    Anyway, is there any difference in using a 19" tall radiator vs. a 17" tall unit? Radiators.com needs to know which I have. Also, a friend has a 4-core unit hanging around (brand new). Is there any difference between the GM 350 car radiator and 350 truck radiator? Will certain measurements fit while others won't?
    Thanks in advance.
    Dave
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    if your radiator mounts bolts to the top of the core support you have the 19" core. the mounts are different for the 17" core and bolt to the back (engine side) of the core support. either mount will bolt to your support. the fan shroud is also different.
    if you go with a 4 core, you need to get 4 core mounts for the size core you have. they are different between the 2 and 3 core radiators.
    the core has to be the right width and height (hard to find a tall one in a car) and have the hoses in the same area.
  3. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    Well, the PO of my truck put in what must be the 17" tall unit ... where a 19" had been. They solved the height issue by cutting heater hose and duct taping it into place underneath. :angry1:
    If you're gonna put in the other-size-than-what-you-have, you'll need to change the rubber mounts and top and bottom, plus maybe something up top? I just put in the right size for the truck, and voila, it fits without vibrating all to hell (gee, wonder why the fittings leaked?)
    -- A
  4. 91VJimmy
    Dec 20, 2004
    11
    Brookings, SD
    I know now that it's the 19" radiator. Thanks for the input.
  5. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    Going to a 4 core is never a bad thing. Just need to get the upper mounting brackets since it is thicker.
  6. 91VJimmy
    Dec 20, 2004
    11
    Brookings, SD
    Okay, now I have just one more Q;
    I am 100% sure I have a 19" tall core. I also have the brass endtanks. Radiator.com told me they have all-metal and metal/plastic radiators. I can get a junkyard one for $85 but can't be sure if it's the correct one until I get out there. Also, there is no return on that--only credit. The online one is $139 with a 1-year warranty. What should I do? I'm not committed to this truck for much longer than a few months, but it needs to travel a lot in that short amount of time.
    I suppose my question is whether or not the plastic endtanks are standard in the GMC Jimmy, and whether or not they came on the 3-core radiator (A/C and AT). Thanks for the help.
    Dave
  7. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    I got mine from www.1800radiator.com, I think it was more than $139. But, I got a 4 core. I know it was less than $200 shipped.
    I would go for a new one. Some things I just dont do used.
    Radiators being one of them.
  8. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    Oh, and mine is all metal.
  9. 91VJimmy
    Dec 20, 2004
    11
    Brookings, SD
    Yeah, I don't think a junker is the way to go either. If you had to junk a K5, then you probably didn't give a crap about it from the start. :D
    I will go with the internet one.
    Thanks, Ken.
    Dave
  10. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    plastic tanks are ALWAYS a bad idea:xmas:
  11. 91VJimmy
    Dec 20, 2004
    11
    Brookings, SD
    Yeah, you're talking to a former SHO owner here. First one I had split the tanks after a few weeks of ownership. (No Ford cracks here, that's a Yamaha motor and Mazda drivetrain!)
  12. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    Oh yeah, I meant to say that too... No thanks to the plastic.
