Radiator troubles
Discussion in 'The Garage' started by Chevy305, Apr 30, 2006.
  1. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,230
    488
    New Hampshire
    I replaced my radiator a little over year ago with a bigger one I got from LMC. The thing has never overheated once and I was very happy with it until now. It is leaking (slow drip) from somewhere right by the lower hose on the passenger side. Looks like it might be the seam where the rows/fins meet the side part of the radiator. I have looked and it is not the pet cock (gigidy gigidy) and it is not the hose either. Does LMC warrenty their stuff? Also if not, what kind of that radiator stop leak stuff works the best?
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    remove it, lay it flat, buy some solder and a propane torch, maybe some cleaning flux, and solder it up.
    I had to do this to a truck i got awhile back, the heater hose nipple was leaking, soldered it up and no more leaks.:D
  3. dyeager535
    26,979
    I second the pull/solder method, I'm not a big fan of the stop leak stuff unless it's an emergency.
  4. Chevy305
    Jan 23, 2006
    11,230
    488
    New Hampshire
    Thats a much better idea! My propane torch I have just ran out of propane, can I refill it, or do I have to buy a new one?
  5. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    stop leak is uhmm bad
    petcock is on driver side anyways, so
    solder is your best friend
    good luck
