radiator upgrade
Discussion in '1936-Present Suburban' started by m4, Feb 13, 2005.
  1. m4
    m4 1/2 ton status
    Sep 26, 2004
    286
    Texas
    Hello all, I have a 1991 Sub 4x4 and would like to upgrade to a larger radiator. The factory temp gage shows 210 degrees in the winter time. This is with a 195 degree thermostat, new crate motor and new radiator. Is this normal? Doesn't give a warm fuzzy for summertime with A/C on. If a bigger "ie" wider radiator is installed I'm not sure the rubber supports would fit right? Any help would be great.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Sounds right to me....but if your really concerned about it, upgrade to a 4 core radiator.
  3. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    yeah modien 4 core will frezze your ass
  4. flatline
    flatline 1/2 ton status
    Sep 9, 2004
    167
    Cincinnati, Ohio (area)
    Go to RadiatorBarn.com
    I bought a 4 core for around $127 w/ free shipping
    works like a charm!
  5. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    i snagged a 4 row for my 91 sub from radiator.com. seems it was less than $200/shipped, and mounting it was pretty easy. I needed the bigger rubber mounts for it, but they fit into the stock lower tray (if memory serves right).
    Was able to tweak the upper mount to accept it as well, but had to fab some extensions to get the fan shroud to still work.
    Pull a travel trailer with the sub, and it runs SUPER cool now!
  6. m4
    m4 1/2 ton status
    Sep 26, 2004
    286
    Texas
    Thanks, I tried a four core when I first started the radiator swap then went to the factory size after a saw it wouldn't bolt in. Now a year later I want the four core! Anybody using Jacobs/msd/mallory ignition stuff and do they make any difference. I have to get a cortizone shot in my neck tomorrow so no wrenching for a few days.
    thanks all
  7. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    I installed the four core from my '77 P/Up....Some day I will work on moving the mounts and holding it in with something other than zip ties....
    I usually do not run a shroud, and have had no problems....
