Radiator
Discussion in 'The Garage' started by 79cheyenne79, May 16, 2006.
  1. 79cheyenne79
    79cheyenne79 Registered Member
    Aug 14, 2005
    29
    maryland
    When I start my truck the temp goes up to 260. Then after I hit the gas for awhile the temp drops back down to 180 like it suppose too and a few times not that often once in a blue moon it will happened while Im driving. What do ya'll think it is. I just put the temp gauge in last week and I had the truck for about 1 yr. Its a 79 k20 long bed 5.7 4bbl :mad: :doah: :yikes: :confused:
  2. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    thermostat maybee? how old is it....
  3. dyeager535
    26,980
    If the gauge is accurate, I'd bet the thermostat is sticking.
    Parts store cheapies are a coin toss if they will work brand new out of the box, a Delco thermostat is a good choice.
  4. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    agreed.
  5. Kyle Strong
    Kyle Strong 1/2 ton status
    Sep 26, 2005
    280
    Eugene, OR
    yeah, I'm fairly sure the t-stat is sticking. They're cheap. replace it.
  6. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Check your coolant level, i thought i had a bad t-stat awhile back, did the same thing, went to tear it down and replace it, and found it to be very low on coolant.
    Found that i had a very slow, small leak from the rad hose to the intake, fixed the hose, and went ahead and replaced the t-stat,,,,,,no problems since.:D
  7. 79cheyenne79
    Aug 14, 2005
    29
    maryland
    i changed the t stat im letting the silicone dry overnight and hopefully i wont see that problem any more. I got a t-stat that is set at 160 is that cool? i think its suppose to be set at 180
  8. dyeager535
    26,980
    Stock GM is 195*, if it doesn't stay cool with a 195*, any other temp t-stat is a bandaid for another problem.
