Radiator ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RAY, Apr 25, 2002.
  1. RAY
    RAY 1/2 ton status Premium Member
    Jul 4, 2000
    281
    Austin, Texas
    Is there any difference (size and # of rows) between a stock 305 radiator and a stock 350 radiator.
  2. dyeager535
    26,979
    There were various different radiators offered based on numerous other options, but I'm not sure what all GM used to base these on.
    Just took apart a manual trans '85 K5, 305, that had a 3 blade fan, no AC, and a 2 core radiator that was not the same height as the core support.
    You can speculate as to size, but if you are buying site unseen, you'll need the exterior measurements to compare. Bracketry and fan shrouds are different depending on radiator size.
