radiator
Discussion in 'The Garage' started by RatMan, Jun 13, 2003.
  1. RatMan
    RatMan 1/2 ton status
    Jul 27, 2002
    270
    Marietta, Georgia
    ok, i got a big leak in my radiator and need to get a new one, but apparently there are two different sizes availible. is there a way to tell which size i need without taking everything apart first? tia /forums/images/graemlins/grin.gif
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Stockers came with 3 rows and BBC and diesels have 4 rows, if your overheating at all I would swap in the 4 row...
  3. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    good call, assuming the thing will fit, go for the big'n. when i had my engine swapped, the gm mechs discovered that a shady radiator repair guy had cut a loop or 2 out of my rad instead of brazing it or suggesting that i get a new one. /forums/images/graemlins/mad.gif at any rate, they installed a big ass radiator (no doubt the biggest most spendy one they had on hand) and boy does that bad boy keep things cool! I used to over heat all the time on long hills and stuff, and now the temp gauge is steady as can be, nice and cool. /forums/images/graemlins/grin.gif
    j
  4. RatMan
    Jul 27, 2002
    270
    Marietta, Georgia
    the problem i am having is that there's a 19 inch radiator and a 17 inch radiator availible. i just dont know which one will fit my truck.
  5. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    so measure from the bottom of your radiator to the top, see if its 19 or 17", i believe thats what they are referring to
  6. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    If I remeber right the 19 inch one is flush with the top of the core support, so the brackets basically go straight out. The 17 inch one is 2 inches shorter than the core support, so the brackets dip down.
