Radiators for 6.2??
Discussion in '1982-Present GM Diesel' started by JHG, Aug 5, 2002.
  1. JHG
    JHG 1/2 ton status
    Jul 28, 2002
    129
    Iceland
    I have to replace my radiator on my K5 (with 350). The radiator has only 2 rows.
    Because I have been considering swapping in a 6.2 diesel I was wondering how many rows radiator I would need for that engine.
    Will 3 row radiator be enough?
    Thanks,
    Jon H.
  2. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    The small 6.2L radiators are three row, the heavy duty are four row. Both are also a lot wider.
    I would go with a four row myself. They are more rigid and don't flex as easily as the three row which can make them leak.
    Then you'll have all the cooling you'll ever need.
    Casey
  3. KRUM
    KRUM 1/2 ton status
    Dec 17, 2001
    159
    Signal Mtn
    what did the the 3 and 4 row radiatorcome out of? /forums/images/icons/confused.gif
  4. arveetek
    Mar 1, 2002
    722
    All 6.2L diesel equipped trucks come with at least a 3 core radiator. Most 1/2 ton Suburbans, pickups and Blazers have 3 cores. The heavy duty (20 and 30 series) trucks come with a 4 core. The tanks are big enough that you can actually install a 5 core if you wanted to!
    The 3 core radiators flex and crack easily.
    Casey
  5. KRUM
    KRUM 1/2 ton status
    Dec 17, 2001
    159
    Signal Mtn
    so a cucv with a 6.2 would have a 4 core?
    thanks,
    KRUM
  6. arveetek
    Mar 1, 2002
    722
    Yeah, it should.
    Casey
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Mine did.
  8. kickinasphalt383
    kickinasphalt383 1/2 ton status
    Dec 6, 2001
    224
    Michigan
    who makes a 5 core and how much? thanks
  9. arveetek
    Mar 1, 2002
    722
    My local radiator shop quoted me about $250 or so to have a 5 core section mated to my original end tanks. If my current 4 core ever develops a leak or needs to be rodded out, I'll install a 5 core then. For that price, you can't go wrong!
    Check with your local rad shop and see what they say.
    Casey
  10. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    there is one thing about going to so thick of a radiator , it may not actually cool good because of the thickness , this was told to me by a man who has raced stock cars , been a high school shop teacher for a loong time ,and had a radiator business for a lot of years also . so im not talking out my neck /forums/images/icons/smile.gif
  11. AzzKicker
    AzzKicker 1/2 ton status
    Jul 28, 2002
    265
    Edinburg, Tx
    that would seem realistic to me being that the way they should work is for cool to flow through and hot to leave. If its too think, you dont get enough hot leaving than you should so you just make it hotter.
