Radiators
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fr8train, Mar 30, 2001.
  1. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Ok working on a 88K5 Blazer with a semi-built 350TBI. Its equiped with a 19" tall radiator. She has ac/and a tranny cooler. What I am wondering is can we use a big block 4 core? If so what model, year, and engine size? I have a kick a$$ contact at this radiator place and we are trying to make it work out for the folks on this site.
    [​IMG] Dont steal my truck..I dont need anymore worthless junk over my fireplace.
  2. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    I had a small block hooked up to a diesiel radiator. I'm sure that would work too.
    <A target="_blank" HREF=http://muddin4fun.coloradok5.com>http://muddin4fun.coloradok5.com</A>
  3. fr8train
    Aug 2, 2000
    1,712
    Maryland
    Off chance you wouldnt know how many cores were in it would you? Cores are the little rows of metal pipe that flow the rad. fluid around to cool them. We want four core( 4 rows ) since its a hauler and slow speed rig with a/c. Its got a three core but it ran too hot last year. Changed out the thermostat and suff, even got a seperate tranny cooler to cut down on heat. All of it helped, just not enough to satisfy my client.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Look up the part number for a Suburban of that same year with the 454 and towing package. That should be a 4-row radiator.
    I've got a healthy 383 in my K5 and it runs cool with the stock 3-row radiator. I had the radiator rodded and boiled to make sure that coolant was really going through all of the tubes. Are you sure that your client's radiator is working at 100%?
  5. fr8train
    Aug 2, 2000
    1,712
    Maryland
    He got it rodded and took the rig to me after he got away from the shop. Normal driving city/hwy is fine she hovers in the 180-200 depending on a/c. When we add the boat or camper she goes over to 220 and up. he boiled it over following me to the Shenandoahs last year. I am installing a high flow water pump after we install the new radiator. A brand new radiator for the truck three row to my door 169.99 and my guy is taking $5 off. He wanted to know what radiator would work for us in big block. So we can figure the price. As it stands the Big Block radiators cost me 189.99 to my door. I just want to get this thing done right without killing my clients bank account.
  6. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    I don't remember how many cores there were. Prolly the same as a bigblock I would imagine. I'm not sure.
  7. fr8train
    Aug 2, 2000
    1,712
    Maryland
    Lara/Harry, really, thanx for the quick input.
  8. Emmettology 101
    May 9, 2000
    8,126
    FL
    I believe the Diesel radiators are the largest you can get that came factory. I know mine was huge. It went almost from one battery to the other!!!!!!!! Plus it came up over the core support some too!!!!
    Definately find one of these. Mine is an 82 Jimmy that originally came with a diesel....
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
    "He who uses a winch...... Is tired of yankin!"
  9. fr8train
    Aug 2, 2000
    1,712
    Maryland
    Geez. Does anyone know the measurements for this thing? Where are the water inlet/outlet couplings located?
  10. Emmettology 101
    May 9, 2000
    8,126
    FL
    I used normal hoses to route it for a diesel to my SBC.... There are a couple extra supports coming out from the core support on the ends(just made of plastic) and it extended up fro the core support about an inch or so...
    It cam within about 3 inches of each battery tray... I know you can get them at places like Auto Zone for about $360.... Or my junkyard said he could get a good used one for $100....
    I would have to say it was roughly:
    30"-31"L x 20"-21" tall... And was a four core I believe which was about 3"-4" wide.....
    Mike [​IMG]
  11. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Don't you need to change the core support to really make the diesel radiator fit properly? I thought that parts of it get blocked with the core support from a gas rig.
  12. Emmettology 101
    May 9, 2000
    8,126
    FL
    My core support air hole is roughly 28"Wx 17-18" H
    It is what came in it originally withthe diesel...
    The diesel radiator extended past this hole all around!
    Mike [​IMG]
