radio digital face dead, motor noises in speakers
Discussion in 'The Garage' started by R72K5, Mar 5, 2004.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    92 truck with stock radio in it, has the blue digital LCD screen, well the radio turns on and off but the screen is dead and you jus hear lotsof electrical humming in the speaker and when you turn on wipers or anything electric then it gets worse bad and if you pull and replace fuses then it makes static noises and all kinds of stuff in the speakers, just started the other day
    entire dash was pulled off of truck over a year ago to replace heater core btw
    also cig lighter is dead now and dahs lights work though, all fuses check good
    radio fuse did burn once about two weeks ago
    radio is total stock origial no wires are cut anywhere in this truck at all
    any ideas ?
  2. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    9/10 it is a bad ground
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    ground for just the radio, or for soemthing else thats an electric moving part and interfering with radio ?
    hmmmmm..
    the latter wouldnt explain the dead radio face though
    thanks
    /forums/images/graemlins/laugh.gif
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    hmmmmm..
    oh and it makes the electric motor humming noise with engine running or not(radio only works with key on of course), doesnt matter which
    thanks
  5. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    I'd check the grounds first.
    If you still have a problem after that, you can go to radio shack and buy a capacitor, attach one end to the radio hot and the other to the radio ground.
    That way if you are getting some sort of high frequency interference it will jump the capacitor and stay out of the radio.
