Raditor Overflow tank... how?
Discussion in 'The Garage' started by BozoWise, Sep 1, 2005.
  1. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    It is my understanding that our raditor will expel fuid into the overflow tank when it expands and then suck it back when it contracts. I have lost my factory tank due to narrowing the front and found some on summit. Part number SUM-G1476. I saw this same one mounted on some other members rides. Couldn't find it on a search now that I need it.
    My question is do you mount a hose inside this piece to go to the bottom of the tank so it can suck fluid back out or is there another tank for the reciculate that isn't going to break me $-wise.
    Heck I even thought of just building one from pvc :doah:
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you do not need a hose running to the inside just have the connection to the raditior at the lowest part on the overflow tank then when the raditior cools off and the fluid contracts it can suck fluid back into the raditior
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Yep. The hose connects to a fitting at the bottom of the overflow tank.
  4. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    Boy that was too easy. Great I will just connect it to the drain on summits piece. I must have had another brain fart on this one, they are getting more common as I get older.
  5. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    One key point is to mount your overflow tank as high as you can in your engine bay. Keeps the air out of your cooling system :D
  6. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    I am replacing my overflow tank next week. I am buying a summit overflow tank and I am going to mount it next to my rad on the Radiator Core Support. I will show pics when it is done.
    Adam
  7. CK5
    May 19, 1999
    21,622
    701
    CO
    Really? Then whats the top one for? Shouldn't the suction pull the fluid back out through the top? Then the bottom one is simply for draining excess fluid out if needed?
  8. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    FWIW, i saw at GI Joes the other day generic overflow tanks which would probably work for pretty cheap.
  9. skidpan
    skidpan 1/2 ton status
    Sep 21, 2005
    226
    SOCAL
    i just used a jack daniels bottle zip tied to my core support. it looks better than the stock one, and its was way more fun to install/empty...
  10. CK5
    May 19, 1999
    21,622
    701
    CO
    I have the Summit one and it would seem that it would work the same as a JD bottle, hose comes in at the top?
  11. nemesis_pyros
    nemesis_pyros 1/2 ton status
    Mar 24, 2004
    229
    Winnipeg, Manitoba
    I have a pepsi bottle with the hose through the cap. It works ok and looks horrible, but ya it should pull fluid from the lowest part of the "tank". Whether that is a hose from the top going to the bottom or a fitting on the bottom of the "tank".
  12. CK5
    May 19, 1999
    21,622
    701
    CO
    I guess so, just looked at a few of my other rides, and it connects from the bottom, I haven't had mine stock for years and didn't remember.
  13. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Some have a tube that goes down through the cap and reaches to the bottom of the tank. That type usually doesn't have a fitting at the bottom at all. All of my GM junk just has a single fitting, at the bottom of the tank.
  14. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I bought a large "overflow" tank kit from Kragen for about $13. It came with the bracket, tank, and hose to connect to the radiator. It had a connection at the top and the bottom but no valves. I connected the radiator to the bottom of the tank.You can put a piecec of hose on the upper connection so when the tank overflows it will blow down on the ground and not all over the engine compartment.
    I will go outside and get some pictures of how mine is mounted.
    Ira
  15. sandawgk5
    Oct 28, 2003
    6,881
    Here is how mine is mounted. As you can see from the pics I had to move mine due to not having inner fenders anymore.:D
    I have not driven her in like a month due to being out of state apparently I need to add some water:doah: .
    Ira
  16. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    did you construct that bracket, or is that what came with a kit?
  17. sandawgk5
    Oct 28, 2003
    6,881
    It came with the kit. It actually snaps around the tank and locks it into the bracket.
    Ira
  18. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    i like that.
  19. sandawgk5
    Oct 28, 2003
    6,881
