radius arm set up
Discussion in 'The Garage' started by supermanmudracing, Nov 27, 2005.
  1. supermanmudracing
    supermanmudracing Registered Member
    Nov 17, 2005
    12
    north carolina
    im building a radius arm set up for a 1996 s-10 can anyone help me on how i should measure for the link bars
  2. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    More info is needed.
    Radius arms + trac-bar ala Early Bronco's?
    Application/intended use?
  3. supermanmudracing
    Nov 17, 2005
    12
    north carolina
    radius arm set up like early fords with pan bar. i use this truck to mud race.i have a 555 ci bbc in its stock location, im going to stretch the front end 12" past #1 plug and i was wanting a good arm length,not to short or not to long.truck can be viewed at www.webshots.com,click on community, then find a member, type in chaderic
  4. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    I would set the radius arm length so that the front driveshaft has the least amount of plunge as possible. This will cut down on suspension binding under power.
    Look at how the Range Rovers and FJ-80's attach their front radius arms, far superior to the Ford design and much easier to fab.
    Ideally the trac-bar and the drag link will be the same length. They will also be parallel as veiwed from the front and from the top with the vehicle at ride height and with the steering pointed straight ahead.
    If they can't be the same length then you need to set them up so that the arc of each closely matches the other within the normal range of motion. Which means they won't be parallel as viewed from the front.
