Rag Joint removal
Discussion in 'The Garage' started by 1987Chevy, Jul 21, 2005.
  1. 1987Chevy
    1987Chevy Registered Member
    Jun 29, 2005
    51
    Connecticut
    I was trying to replace my rag joint and It seems as though there are 2 bolts and then two things that look like pins holding it in. I got the bolts out fine but have no clue how to remove the pin things.
  2. diesel4me
    Jul 24, 2003
    17,584
    945
    Massachussetts
    does not come apart...
    To take off the rag joint,you need to remove the special 12 point bolt that holds it to the steering box,then pry it towards the cab until it comes free from the steering box,then the 2 bolts that hold it to the steering shaft come off to release it from the shaft--those "pins" are swedged in the rubber/steel rag joint like rivets,they cant come out..the rag joint is replaced as an assembly,unless you bought just the rubber disc separately..if you did,I'd trade it in at a parts store for the "Complete"rag joint--"HELP" brand sells them now,as well as GM dealers and other brands--better bring the old one with you-some had different size splines on them... :crazy:
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    the pinch bolt is i think 12mm and is the 12 point headed bolt
    the pins you dont worry about, its part of shaft
    take bolts and pinch bolt out and thats it
    intermediate shaft will move up twards column a little so you can get rag off
    youll see..
    once youve done it youll always know
    good luck
  4. 1987Chevy
    Jun 29, 2005
    51
    Connecticut
    thanks for the help
    all I bought was the rubber disc that kinda sucks thanks for the help
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    i just did this repair on my truck, i bought just the rubber disk. Once i removed the join i grinded the studs that are there flush with the metal peice and then drove them out. i first removed the rubber disc entirely though(cut it off) now i got 2-5/16" bolts 1 1/2+" long (dont remeber exactly) 2-5/16" fender washers, 2-5/16" lock washers and 2 5/16" nuts (all grade 5) I then put the bolts up through the bottom of the metal piece, then place the rubber disc on top of that, then fender washer, flatwasher, nut. I used fender washers to spread the load out over the rubber. You have to make sure the bolts ar long enough to grab the steering arm like the old studs did. i havent had any problems yet and have used it for over a month, everything is real tight. ill snap some pics later and post 'em up if i can.
  6. 79k20350
    Nov 22, 2004
    7,757
    Ct
    P.S where in ct are you?
  7. 1987Chevy
    Jun 29, 2005
    51
    Connecticut
    thaks
    thanks for the advice i'm in the new britian area right in the center
