Rag joint - where to get?
Discussion in 'The Garage' started by BurbinOR, May 14, 2002.
  1. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Doing the ORD crossover conversion tonight...........would have been done but for the spline diameter difference between my factory 79 box and the AGR box. AGR box is the larger diameter.......where to locate the larger size? Is this a parts store part?
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    The actual piece you are looking for is going to be a dealer or wrecking yard item. The actual rag joint itself can be bought in a parts store but not the splined piece you are referring to.
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    check out borgesen and use a ujoint
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I think going w/ the u-joint like MJ said would be best (zero slop!). If you want some more info check out kpanza's posts over the past 2 weeks...he has gone through the same search.
  5. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    www.classicindustries.com
    Download their 60Gig catolog or order it by mail. They have some amazing stuff. I think I saw a rag joint somewhere in there. Just don't ask me which page it was.
    Hope this helps.
