Rain leaking into cab
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mastiff, Jul 18, 2003.
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    It drips down from above the parking brake pedal onto the drivers floor. Any idea where it's coming in? It has persisted through a windshield replacement, so I doubt it's that seal. I'm not sure where else to look.
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    metal where the firewall meets? Maybe the seal there isn't so good for some reason. I hate finding mystery leaks. My K5 always had one where the carpet right behind the driver seat got wet but nothing in the truck got wet except that!
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Mine was leaking in the exact same spot. I just ran a bead of clear RTV around the windshield and it stopped...
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    try looking at the firewall and also pull the fender off and look there
  5. dyeager535
    26,975
    The windshield is the most likely culprit, but there are a couple of other things to check.
    Kind of a PITA, but pulling off the cowl piece, and checking the drains in the corners for junk, is always a good idea. It may plug up and then water backs up into all sorts of places.
    Along those lines, if the windshield is leaking more likely than not you've got rust started. If you catch it early you can prevent a lot of damage, if not, you'll have real problems as that is where two panels of sheet metal run together, and water will get in between them. Gotta pull the windshield to check, but if you care about rust, thats a definite must.
  6. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Which is the cowl piece? Is that the one right in front of the windshield?
    I doubt it's rust related, since it's been going for quite a while, including when it was in mint condition in the dry desert out west.
    Thanks.
  7. dyeager535
    26,975
    Correct. One right behind the hood.
    Hope not! It may very well be that the seal is a bit weak from the desert heat.
  8. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I have some of that thin silicone for going after leaks, would I put it between the glass and the rubber seal? Or between the metal and the seal? Any particular spot, like the bottom driver's side corner?
    Thanks.
  9. dyeager535
    26,975
    Yep, both corners between the seal and glass. For a short term fix o mine, I used vaseline on he glass right at the corner.
    Spray water on your windshield and look at how the water runs to the corners of the seal, and sits there.
