Rain making motor cut out?
Discussion in 'The Garage' started by trev1981, Feb 7, 2007.
  1. trev1981
    trev1981 Registered Member
    Dec 21, 2006
    72
    Manteca, CA
    i just bought my 84 blazer a few weeks ago, it runs rough sometimes, low on power, and now when i drive in the rain its 10x worse. At first i thought it was the carb, but now i think its the ignition. What do you think? It has new wires.
  2. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
    Similar thing happened to me, turned out that the intake manifold was cracked and causing a vacuum leak and cold starts and moisture make it run worse.
    But there is the possibility of moisture condensing on the inide of the dissy cap.
  3. BlaKK54Speed
    BlaKK54Speed 1/2 ton status
    Dec 14, 2006
    242
    Omaha, NE
    make sure your dist cap is on right/tight. if its loose or not sitting right and it gets wet in there it will run like crap and possibly stall out
  4. trev1981
    Dec 21, 2006
    72
    Manteca, CA
    just got done changing plugs and the coil. Problem seems to be gone. one of the plugs was alittle wet and oily. what would cause that?
  5. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    usually a valve cover leaking on it.
    It it happens again, mix a water/soap mixture in a spray bottle and while the engine is running spray the distr. cap with the mixture and if it starts arcing then that is your problem. Will also work on the wires, but you already fixed that issue. Must do this inside the garage or when there isn't too much light outside so that you can see the arcing.
